no 3s on retract board.. i plugged in my turbine battery during setup and smoked mine last night.. it also took out the motor to the right wing i had attached...more parts needed now.
lior
did you mount the thrust tube flush at the rear or is it inset from the fuse a bit.
also what amount of space did you leave for the 140 between the pipe and the tail of the turbine.
thanks for all this info in helping others here.. the odyssey is much lighter weight than my predator of similar size it should fly well
