Originally Posted by
smiller
I have the manual but It does not give you neutral stab setting. Does it line up with the trailing edge of the speed brake ?
Scott
Hi Scott, the only F16 I’ve ever had is a Tams 1/8.
your stab neutral will be dependent on CG.
I would start with a very slight amount of up eleveator.
maybe 1/8 to 1/4” above the speedbrake.
From my limited research the recommended CG and throws seem to be Ok.
Are you getting close to Maiden? What are your thoughts on the build so far?
