RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 10-30-2018 | 06:56 PM
  #6863
allans
The cap may a bit loose and you may have to crimp it a bit. Be sure that the side of the cap are as far down on the plug as it can go. There is a ring on the bottom of the cap to supply some holding tension. But if you think the cap is loose crimp it a bit . It should take some force to get it off.
