ORIGINAL: I & C Tech
I'm moving my stock tank back to the CG. Do I need to take any precautions to protect the wood in that area? Should I cut out room for it leaving it tight against the fuse or make enough room for foam and such? Will the tank expand under (YS) pressure? Thanks!
I spayed a coating of clear lustrecoat into the fuse. Wrap your tank with filament tape to reinforce it. There are some pics of tank installation at cg in this thread which should give you a pretty good idea how to do it
