Originally Posted by
digitech
Throws :
Ailerons Flight/landing Primary 10mm up and down / (Differential 78% on down) 45% expo
Elevator Flight 13mm up 13mm down /landing 15mm up and down 45% Expo in flight 25% in landing
Rudder 25mm
Crow Flaps 70MM / Ailerons 5mm up / Elevator 3mm down mixed.
CG for start just after the wingtube / max is 20mm from center of the tube backwards!.(100ml fuel in tank)
or if you have a CG Wizard its 68mm.
Visual inspection : the Rebel hot would stay on its tail if you push the tail down (tank 10% fuel remained) if you lift it about 20mm it will fall back on the front.
Radio we used : DS-16 receiver REX-12
extra,s
Cortex pro
Digitech TTU (Telemetric)
2 x Lipo 1800 2S for radio
1 x 3S Life 1800 for turbine
Turbine Kingtech K-70
Total weight with this setup 5.7 Kilo (painted outside the mould)
Just to be sure the 15mm elevator throw is measured at the tip right? Looks a bit much so wanted to be sure.
Chatty.
