I chose the Falcon gear because they were lighter. Falcon also makes a shorter gear that fits as well. It's the number 102 gear. The two holes on each fuse side are too wide for either the CA landing gear or the Falcon gear. I simply just drilled holes that were less far apart. I used the factory ply battery tray. It was fairly light. I did paint it black simply for looks.
Reason: attachments
