now when i get a nice day i will run the new swiwin 140b in it then i only need to setup the ar3000 gyro that right now is not plugged in for first flight... balance with the uat full came out right about the 220mm mark with gear up.. i need to tidy up the fill line and i think im rtf.... i am using the stock gear and controller but should have a pilot controller for the gear here in a few days. it has rt/left adjustment for brakes and abs selection too....will help a bunch with the stopping on this one.. stock controller is not very user friendly about how much brakes you can dial in on a slider. it goes far enough to lock up then you can feather it off but it doesnt feather on very well.
any input as to use some down elevator mix with flap settings some i read do others say nothing needed..
construction was simple and finish is pretty darn good for the price..
