Originally Posted by
RichJohnson
How are you supposed to glue parts with JB weld. That stuff is a metal epoxy putty that i wouls not think could be used to glue small parts together. How would you get it inbetween two parts and keep them tight?
You just spread it along the joint and work it along the way.
I have been using it for most permanent joints since Carson recommended it to me.
Since the Leopard 2A4 has different hull details, I have cut off the threaded tab from my metal Leo2 hull and hold it together with JB weld instead. It has held on for months of off-road bashing without fail.
I used normal epoxy before and it has broken off twice.
There are modelers who built entire tank out of CNC aluminum sheets, milled joints held together solely by epoxy.
