RCU Forums - View Single Post - Help with Turnigy servo speed controller
Old 11-07-2018 | 05:13 AM
Appowner
Banned
I wouldn't say it's labeled wrong. What you have are two different manufacturers involved who wire their servos differently. You'll notice the "S" or Signal wire is in the middle. This holds true for all manufacturers. But the + and - can be reversed depending who the manufacturer is. I know Futaba and JR are opposite each other. But their servo connectors can be inserted upside down in the others Rx thus allowing a Futaba servo to connect to a JR receiver and vise versa. With some a slight modification to the servo plug may be needed. You'll see a little tab or key on the Futaba. Carefully shave that off and the plug will easily connect to other brands.
Two things to note, the black or brown wire is typically the - or negative lead. All Receivers I'm familiar with have the Neg pins closest to the end of the Rx as viewed from above or closest to the bottom as viewed from the connector end. So, as long as all the Black wires line up in the Rx, you should be good to go. Most Rx are also labeled today but as they get smaller my eyes have enough trouble just seeing the pins let alone some micro label.
When in doubt, plug in a servo to see where the Neg wire falls. Then add everything else.
