RCU Forums - View Single Post - kingtech turbine rc engine k70g2 fatal problem
Old 11-08-2018 | 02:44 PM
rhklenke's Avatar
rhklenke
My Feedback: (24)
As I mentioned above, I had an engine from another manufacturer that did the same thing *twice*. It came to pass that that engine developed a history of doing that, so when I sent mine in, it was repaired at no cost to me (*twice*). I did hear from other guys with that engine that the first few times it happened there was some push-back from the manufacturer that it was a user problem, not an engine problem. However, after the engines started coming back with the same issue, the manufacturer realized that it *was* an engine problem and they came out with a new compressor and started replacing the ones on the failed engines for no cost.
Different manufacturer, same issue and initial response. See Len's post above - it can happen to any of them...
If you want bullet-proof tanks, go with AMT's or old JetCat P-120's...
Bob
