RCU Forums - View Single Post - Shaping Ailerons or Flaps from Solid Balsa Stock.
Old 11-09-2018 | 09:36 AM
r ward
if you're building up ailerons, the best grain orientation would be from sheets that are as close to plain sawn as possible. the strength of this type of aileron comes from the type of construction, so the grain orientation of the component skin should be such that growth rings travel through as much chord of the aileron skin as can be had..
