Originally Posted by
i3dm
sYou can install the FCT in any orientation you want as long at the fitting coming from the main tank is in the top dead center.
thanks. Good to know orientation is not an issue.
Was still considering putting UAT by front gear to help with CG. So I presume no issue running fuel extra distance from having UAT clear up front and back ?
aporeciate all the advice. Thanks.
