Originally Posted by
causeitflies
What is greenhouse kerosene??
it’s your standard kerosene that is used in heaters inside greenhouses. Nothing special. Same as what we use in our turbines. Just make sure you filter it as I have seen the odd tiny bubble of water floating in it. Using a Mr Funnel is probably one of the best. You can also use a dry chamois which also does a good job of filtering moisture/ water.
