Originally Posted by
r ward
are the typical 12 volt Hobbico deluxe starters considered "cheap bargain types "?. these two Hobbico's are the first starters I've ever used, or even handled for that matter.
Hi r ward ,
Unfortunately , yes indeed "hobbico" branded starters are the same as my "Thunder Tiger" starter , and if you want a starter that truly performs you must look to a company like Sullivan (maker of the "Dynatron" and "Megatron") . I know both of those are crazy pricey (the Dynatron I own is a $126.49 unit and the Megatron will run $270.24 brand new) but the used market frequently turns them up for bargain basement prices , I got my Dynatron in a package deal of used RC components for $50 which included 3 small OS engines , about 20 Hitec servos , and a huge handful of unused wooden props .
You will not hurt your starter and will see plenty of power with the cheaper starters if you hit them with 24 volts . I know you mentioned a 4 AH battery , if you were to try two 7 AH 12 V gel cell batteries in series for 24 volts applied you'll turn over that Magnum .46 just like my TT starter cranks my 2.70 Saito .
