Originally Posted by
Carsten Groen
That requires that the MFlow is calibrated in each plane also ?
(I would guess that the MFlow is not absolutely precise if moving from plane to plane with calibrating it "in the plane" ?)
The mflow does not need callibration. It is an actual flow meter. It is supposed to be accurate to 2%. You set the tank size and it will give you percent or you can just measure the amount of fuel has gone through it. You can even hook it up and turn the radio on and it run it in line of your fueler to measure how much fuel goes in to the plane. It has shown to be very accurate and really like it but don't want to buy one for each plane being that I am running either the Kingtech Telemetry or the CTU anyway and it isn't cheap.
Jeti Telemetry Sensor Fuel Flow MFlow2 Turbine T800 EX
