Originally Posted by
brickwoodward
i don’t know if you’re still on here, but I could use a serious favor?? On the fuselage side view, can you tell me the total length of the fuselage on the bottom? Then, at 90 degrees can you provide measurements at the wing leading edge and trailing edge and how tall the very back of the side view? I have my uncles plans but the side view is missing?
Number 2
this is a scratch built 48 inch Stik with an OS 25. And I have a Saito 150 for the 60 size Stik. Thank you in advance, bill
Here you go for dimensions for a Great Planes Big Stik 60 ( kit built )
Fuse bottom length from fire wall to tail = 46"
Fuse side height at LE = 3 7/8"
Fuse side height at TE = 3 7/8"
Fuse side height at tail = 1"
