Originally Posted by
Ixtrim
possible !
Check out everything. Sure some power missing. It should sound like this :
https://youtu.be/HPcfiCMj_i4
do you have a fuel pump ?
Yes Thomas,Tom's Spit was the first time i heard the 135, so i knew then it was what i needed for my build.
I'll check everything, i need to remove it to paint the plane so i'll have a look.
I noticed the rear cylinder exhaust gas is way cooler than the front.
I'm not running a pump,Hans told me at the time i'd be okay without one?
Another thing i noticed when it arrived, it had the plated cylinders not the machined. any thoughts on that?
