Originally Posted by
jester_s1
If the rudder was working right before the crash and you hadn't unhooked anything, you may ought to check for something broken or bent. A loose servo mount could cause your problem, or a control horn that's been tweaked could too.
Yup. The mishap caused the problem. Most likely there will be more to the repair than Regis has mentioned.
