Originally Posted by
Dave Wilshere
150kg ;-). We have a test procedure over 20kg dry, so makes little difference. Also single servo I don’t recommend, only one gear train in the servo to support shock loads. That is why we have two servos, not torque.
Even on the best, tightest servo gears, over time the vibrating surface while on the ground will wear the gear slop.
Hi Dave,
I really appreciate your contribution and take it very seriously. But we have the weight Limit in Germany and I had to weigh up between the "risk" of the one servo method and the weight. The shock loads are an argument wich I see only by landings - even if the plane is rolling on uneven underground - I will have an eye on it and perhaps change after a season to the futaba A700 servos
Best regards
Marcus
