Anyone making any progress on their Hellcat?
Iironed out all the covering on all surfaces, only took about 45 minutes to do . I have the outer panels about finished up with servos and linkages setup and installed .The retracts and gear doors are also fitted to the center section . I think I will fabricate the rectangular door that is located at the forward top of the gear at the LE area . I will copy this door from my Byron and it should be fairly easy to make up . Next up will be the horizontal stabs and fuselage .
