RE: YS 120 NC Idle & Regulator Screw Exist?
The NC does not have an idle airbleed. The airbleed hole in the carb barrel may have to be drilled out slightly to make the idle lean enough. We usually open them to 1/8th inch. Mufflers for these can be an issue. Check with YS Parts at 775-782-4562 for a replacement.
