I read those posts about the receiver priority and the CB200, I think it was around post #395. After considering all of the information I'm thinking the best option for "triple" redundancy using a CB200 would be to use a REX receiver for one input into the CB200 (Rx1), then plug an R3 into the REX receiver for redundant 2.4, then plug a 900mhz receiver into the Rx2 port of the CB200. Someone else on this thread has mentioned this option as well. The idea here is that the 2 x 2.4 receivers presumably switch back and forth better depending on which has the better signal(?), while the 900 MHz receiver will only take over if both 2.4 receivers fail. What I don't know with this setup is what happens to telemetry? Can I still get telemetry on all three receivers? Also, if I want to include a Cortex Pro in the mix what does that involve? Thanks for the help. - Tom
