OK, got a universal tester and it works fine. The timing light for #1 green comes on at 53* btdc and goes off at 30*btdc. Where does the ign spark? the instructions say it sparks at green light on!! I will try to get an actual spark test later today.
I wish I could rig up a timing light so I could see what the advance curve is actually doing.
update: I did a slow roll with the spark turned on and I get a spark on the sensor exit at 30*btdc. So that should be good to go....
Reason: new info
