Hi Appowner
Thanks for the reply, but I still say the labelling is wrong for the input and CH1. If you theory was correct then CH2 & CH3 would also be wrong.
As I stated above, it is just Input and CH1 that have the "S, +, -" connections reversed. If the Input and CH1 plugs are connected with the Signal side going to the "-" pin and the "-" side going to the "S" pin the everything works correctly.
