Originally Posted by
horsefeetky
just put mine on the bench again toady and leveled the wing to zero incidence and it did move my cg a tad forward it is now a solid 215mm from le
i am going with that for maiden and can move a small brake battery pack later if i want it closer to 220mm
now off to program the as3000 gyro and setup the final throws on the radio going to try and mix a crow in the full flap position also..
Sounds like you are close to finishing also. Good to hear its all coming together.
I also setup the crow to try on mine, Using the throws from i3dm post. Thanks i3dm, so much help here, it is appreciated.
I did put the crow on a separate switch so if I go to full flaps and I am not happy with it at first I can switch off the crow part.
But it sounds like it is a nice plus.
