Left bottom center section almost done - just need to finish mounting of gear cover, complete the gear, wheel cutout and attach a bit of sheet balsa to the back half of the bomb release pylon and sand to shape of wing underside. Then, complete right side. Also, I'm going to solder a nut to the top of each 4-40 rod and then cut a slot across the top using a cut-off wheel - basically, creating a 2-1/4" 4-40 bolt.
