Flap-Elevator mix
Thanks for the inputs!
On my Spektrum DX9 I used the flap menu.
Here I can set elevator down mix for each flap position. But it is hard to change these settings during flight. I have to look at the screen and use the scroll bar to change down mix.
I did not know the flightmode menu remembers the trimposition for each flightmode.
That way I can set the downtrim just by using the ELE trimknob in each flightmode...
I will start with 1,5mm down for 1/2 flap and 3mm down for full flap.
