RCU Forums - View Single Post - AMT NL start up help
Old 12-24-2018 | 02:37 PM
mr_matt's Avatar
mr_matt
My Feedback: (10)
Originally Posted by RayStruik
Ok.
The TMC version is for both propane and kero the same. Only the ARS file is different.
You are running on 2400 baud I assume. Check if control (options page) is set to none.
If you disconnect the glow plug is the light going off in the TMC?
Is the glow plug glowing now? If not check if the glow plug is still ok.
If so than take out the glow plug, connect it to the ECU (red wire) and hold it against the casing of the turbine (black wire).
Go into starting phase by putting the switch into running position.
Cheers,
Ray
Hi Ray,
Where is the light in the TMC for the glow plug? I have checked the plug before but I will do it again. I never saw a failed glow plug indicator in the TMC interface.
Thanks again,
