RCU Forums - View Single Post - 40C, 50C, 100C LiPo Batteries?? Whats the difference??
Old 12-29-2018 | 09:40 AM
ArmyCheif
RustyUs,
Thanks for the info it helped out a lot. He’s using the HX-403 charger. His car has the what I guess is a T type connection. I found a 2 pack battery set 6200mah 60c 2s Lipo on Amazon for about $55. I was just concerned about burning up the electronics by sending to much amps through the system. Based on what I’ve read from the links you’ve provided it doesn’t look like that should be an issue.
