Originally Posted by
jjantti
Not silly to ask. I was already quite fustrated when had this same problem. With 2-pin brake connector included with C&C kit they just didn't work. Luckily my friend gave me a hint. You propably need this cable or equivalent from 3-pin servo lead body combined with your current connectors.
/Jyri
Dansy
I didn’t do the change yet, but I can say I never think of this....I will just pull the pins and insert them in a servo connector, if they don’t fit....I will just install new pins.
Thank you both! That did the trick. I just took the pins out of the two wire plugs and put them in three wire plugs as shown in the picture you attached. I can't wait to try this thing out and hopefully I won't be skidding all over the place on my landings.
