RCU Forums - View Single Post - Jeti DS-24
Thread: Jeti DS-24
Old 12-30-2018 | 12:54 AM
  #1170
HarryC
Originally Posted by Mick Hargreaves
Checked settings again and telemetry is not good on 15. CB200 pin output 15 is set to telemetry. It only works when I cycle between Ex bus and telemetry on pin 15 setting after I have powered up, otherwise the data fields are empty. Can anyone confirm they have this working correctly? Am I missing something simple?
Mick
That's interesting Mick. Several of us have identified that CB200 and CB400 have telemetry connection problems with MBAR sensors, and I have also now found a problem with G-force data from Assist Rx, Tx sees the name but the data field is empty. We will be reporting the issues to Jeti when they return from holiday next year. But not every piece of apparently identical equipment has the problems so it will be difficult to isolate the problems. The issue you are having may be connected.
