Donut, I'd really like to see how you do that. When I try, Cura doesn't recognize the LD-001 and won't allow me to select resin as a material, it only has filament settings.
Here is a link you can check --
http://wiki.peopoly.net/doku.php?id=moai:cura It is Moai specific but shows that you need to add printer profiles specific to your printer. Once you do that, your printer should appear in the list of printers.
Prior to Cura 3.5.1, the Moai did not appear in the list of printers in Cura. Moai profiles needed to be downloaded and added for it to appear in the printer list.
