RCU Forums - View Single Post - Programming 18MZ with 6303 rec for elevons
Old 01-01-2019 | 08:27 PM
mauryr
Try doing everything from scratch: choosing the model type just starts a template within the radio programming, you might have changed something inadvertently. Check the monitor before you change the function assignment and it should work fine. Then do change the channels and check again, if you did it right it will still work!
