RCU Forums - View Single Post - Programming 18MZ with 6303 rec for elevons
Old 01-02-2019 | 08:37 AM
mauryr
Originally Posted by kevinthoele
Thanks modtron. I had someone at home grab my trans and program as described and it works. My issue is I had all that you described except one of the controls was named Ail and the other elevator. Now that I understand the logic that's why elevator would work but not both ailerons
The 18mz will create a virtual channel and call it "elevator", then mix ailerons to it.
You just need to connect to the 2 aileron channels and ignore the elevator one if I remember correctly.
It will use one extra channel for this though, so when you're tight on channels (F-14 anyone?) it is kinda annoying, but it's the way it is.
