Originally Posted by
kevinthoele
The motion does in fact use elevens. The aileron control surface is behind center of pressure so they actually both elevator and aileron go up at same time and down also all four surfaces act together right side both up to turn right. Again this was meant as a way to test my new transmitter on a cheap plane to certify to me it was ready for my new jet
Again thanks for help. It works without s-bus as a three channel receiver and on elevons!!!!!
Sorry for the confusion. I do have a bit of bad news for you about the 18MZ; there are so many ways to do things that it's hard to initially get a grasp on the concepts. I will say one thing that will help you out quite a bit; conditions are your friend....
