Ok so what I decided to do was take my dremel with the router setup and route out the servo mounting area and build a foam plug to fill the hole. It was easier than I had thought and prepared for. I glued the plug in with gorilla glue, and clamped everything in place to dry. Once dry I will re-sheet the area and cutout a new servo mount that I am going to build by going off of pictures I seen from another member.
