RCU Forums - View Single Post - Remote Battery Charging
Old 01-12-2019 | 02:13 PM
OliverLove
Originally Posted by Crius
But, if you insist on doing this, bad idea that it is, the charging port on my JP is simply wired in parallel to the battery input.
Hope that helps.
There isn't a switch to isolate the current from the ECU?
If you could, would you please post a picture? If it puts your mind at ease I'm using NIHM batteries not Lipos. They are very stable.
Thanks!
