Originally Posted by
Jesse Open
It would seem an open connection in the antenna input should show up as GREATLY reduced range during the collapsed tx antenna range check ??? The collapsed TX antenna would likely not show up at CLOSE range but it should severely impair the walkout range, well below the normal.
You would think, right? But no, It ranged checked fine at 90ft, even after the second crash.
