could work but those are only 6v max servos. myself i would choose a hv servo and use 2s lipo pack.. more holding ower at high speeds and better use of the ma in battery you choose. keep things light and small only as needed. i suggest a battery pack of enough size for two flights safe and recharge top off between flights. you will only need rx pack and turbine pack
