elevators not working on 6 planes after 2 year storage.
Ok reposting here. I posted in wrong forum first time.
Hello guys, I have a tactic ttx 650. I have 6 planes stored in memory. Last time I flew my planes was probably 2 years ago. Since then everything has been stored. I decided to start flying again, so I charged up my batteries and checked to make sure everything was working on my planes before I started flying. Here is the strange part, EVERY plane I test works perfectly except for the elevators. Throttle, Rudder, Ailerons,are fine, but the elevator servos seem stuck. No matter which plane I select, the elevators do not work now. I have no clue what is causing this. I never changed any settings before storing my planes. Any Idea what could be wrong? Any suggestions? I noticed that while the plane is powered and I try to move the elevators manually , they will not move, the servos are keeping it locked, as soon as I turn off the transmitter, they move fine. The odds of all 6 planes having elevator problems seems impossible, so it must be something with the transmitter right?
