Originally Posted by
rcmigpilot
Jordan
Out of curiosity how did you eliminate the orange peel in the flite metal that comes from the when the adhesive is sprayed on the back of the foil? I have a BVM 80" F-86 that's ready for its finish. I'd like to do FM, but the orange peel turns me off.
Some sanding and elbow grease will get the orange peel out! I usually start with 320 grit sandpaper and work up to a finer grit. It takes some patience but it’s worth it in the end!
