RCU Forums - View Single Post - Jet Central Cheeta
Old 01-25-2019 | 03:37 PM
HotelSierra
My Feedback: (9)
Originally Posted by JackD
That is not normal. Typical consumption with the brushless starter is not different. My cheetahs and Rhinos are in the 450 mah per flight, so I do 6 flights per charge on a 3800mah battery. Talk to Manny about your problem, something weird is going on if you are using over a 1500mahs per flight. Maybea some huge restriction on your fuel system?
what battery are you using?
I agree with Jack. Bought my Cheetah last October at Best in the West. It has the brushless motor. I typically get 6-8 flights per charge on my BVM F-16. The battery size is 3800mah. Other than reliability, smooth starts and fast throttle response, the sound the turbine makes while quick accelerating and decelerating is uniquely cool.
