Originally Posted by
herrmill
I'll be one of your first customer if you decide to offer upgraded parts for this release. Clark already plans to offer an accurate muzzle brake but much more is needed, if only, some caps to cover those glaring phillips head screws.
I see a ton of new parts for me to make *cough hubs*. Thanks for the heads up on the muzzle, I was going to replace the whole barrel. Many of the parts that are needed for this build I already have on the catalog.
I'm right now looking to squirrel away some replacement tracks. Problem is I'm not a fan of the rubber cheveron tracks being made in metal, and for the build I have in mind the T66 links would not work either. Ideally would be a set of tracks from tamiya, or the same pattern as the tamiya ones just in metal. Been looking around and so far I've been coming up dry.
