RCU Forums - View Single Post - Remote needle valve extension
Old 01-26-2019 | 03:02 PM
Jesse Open's Avatar
Jesse Open
Originally Posted by RacerX9623
I think I’ll cut a slot for a screwdriver. Then drill a hole in the cowl.
And that is a good bet!.
If you like, You can also slip a piece of snug fitting brass tube over the needle and solder it in place. Helps guide the screwdriver and holds it in place during adjustments.
