Originally Posted by
Cajuncharley
I have a Saito 1.80 on my large HOTS. I want to add a pump to the engine. I have used Conley (Perry) Pumps and have really enjoyed using them. I have had half a dozen Saito engines, but never had used a pump on them. I feel my 1.80 doesn't get enough fuel in loops. I am looking for a pump but have had no experience using them on 4 stroke engines. Any help I can get will b greatly appreciated.Charles
how about a pump off an OS 155 (click my first link), but most likely it runs off crank case pressure so you will have to tap the back side of it for a hose barb, and make a mount for it. if you want it check into it well so you will know if you can put a hose barb on it. and you will have to tap the engines back plate..
also, with a pump on such a large engine will you need a regulator ? if you do some of the OS 91 and 105 Heli engines have regulators, I bought some for my Saito engines I will mount inverted, the older os 91 regulator is like $70 or $80, and the newer one is nicer but cost $115
https://www.towerhobbies.com/cgi-bin...EARCH=OSMG2200
newer regulator here,,
https://www.towerhobbies.com/cgi-bin...?&I=LXZTC9&P=7
the older regulator here, Discontinued but still can be found on the net,,
https://www.towerhobbies.com/cgi-bin...?&I=LXMLA1&P=7
there is one more OS regulator, it's the same as the older one in my last link, but it mounts like the newer regulater..
Jim
of course it's a Saito
