I am trying to get the Mbar air pressure sensor to lower the gear and this is how I have it physically set up. I am not sure this is correct way but the only way I could get it to register the pressure.
Here are the instructions I found and programmed it just like this but will not do anything.
Step 1: Create a "Telemetry Control" using the sensor "MBAR: Pressure". Type of control is "Switch". Condition is "X < value" where value is the pressure you consider low (in KiloPascals). Duration is 0. Default is 0%. Switch is none.
Step 2: Create a "Logical Switch". Control 1 is the Telemetry Control you just created above. Condition is "AND". Control 2 is your physical gear switch. When assigning the physical gear switch, start with it in the gear down position. Go to add switch and move the switch to the gear up position. The Control 2 should show a check mark when the gear switch is in the gear up position.
Step 3: Assign the Logical Switch you just created above to the Gear channel in "Functions Assignment."
Any help is appreciated
Nick
