RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 02-01-2019 | 01:09 PM
  #6876
acdii
You wont get the same transition that you get with a glow. My DLE runs pretty much the same as you describe, half throttle and its pretty much full bore and it is tuned correctly. To overcome I used a combination of linkage and throttle curve to get the stick movement to mirror how I want the throttle to happen.
You could swap the carb for a true Walbro, like what I have on my DA-100, which has a much finer throttle curve, but is still WOT at 3/4 throttle.
