RE: .15 Engine Recommedations
Hi GlowPlugBoy,
I have run the Magnum, ASP, and OS LA. It has been years since I've run Fox although I still have some .25 stunts, and 36Xs combat engines in the cabinet, I think somewhere I even has a Fox .59 used many years ago.
The OS LA .15 broken in properly will turn 17,300 on 5% PowerMaster Fuel, 18,000 on 10% and close to 18,300 on 15% using the MA 8X3 SSC prop. The Magnums run similarly. Each engine has its pros and cons but both work well in SSC combat.
