Eric
The carbon bells position is fixed by the former, so you always shim the turbine to be central in that circle.
Canopy glues inside, you must clean the inside surface with a Dremel sanding drum to make it a uniform thickness. You can glue it with ZAP560 and magnets or tack it with thick CA and a kicker that does not fog the clear
pictures through the thread.
