Firstly, knock it off with those negative vibes.
What makes you think the plugs none standard?
Have you tried plugging in a TBU base?
I have the RCTA tiger and panther ring and the default plug they come with is the same molex connector that tamiya use so it would seem odd that the mako would use something different. Why would you expect it to come with a cable? No other electronics board does, that should come.with you battle system.
I've pm'd you the email address you need, I've had much help in the past and Kevin's usually very quick to reply.
You may wish to reconsider the little outburst in the initial post.
